wikdsvt
How can I resolve this?
PCV system is sucking a tremendous amount of oil from the passenger side valve cover.
PCV hose is hooked up to the intake. Supercharger creates so much vacuum it is sucking oil out of valve cover.
Anyone have a solution? I've tried oil separators, various PCV valves, nothing is working.
The Trick Flow valve covers do not have a baffle, like stock ones do. Even using stock valve covers, it will suck oil.
How much? I can fill a 3oz catch can with 1 full throttle pass.
What do imports do when they add turbos?
