parts
superdugge
tci turbo 400 reverse manual no brake 750.00
turbo 400 standard patern no brake 600.0
msd digital 6 used 150.00
mad 6a box 60.00
msd blaster 3 coil 40.00
bg 950 carb 400.00
prc 1050 dominator 500.00
prc 950 carb 700.00
lakewood 90/10 struts fox body 75.00
qa1 14-200 front springs 50.00
hypercoil 14-175 springs 60.00
3.5 inch flowmaster exhaust mandrel bends for a fox with a windsor 300.00
i all so have 7 convertor's ranging from 4200-7000 stahl all turbo spline some are nitrous some are motor bb and sb let me know what ya mite need and ill check them
eagle 6 inch rods 2.100 h beam brand new 350.00
wiseco pistons set of 8.... 16.1 compression 4 inch stroke /6 inch rod 4.155 bore 400.00 used
diamond pistons set of 8...14.1 compression 4 inch stroke /6 inch rod 4.155 bore 400.00 used
sbc dry sump aluminum pan and pump /tank with lines 600.00
lunati pro series 4.00 stroke crank used 2.100 rods/400 mains 800.00
4 bolt 400 block filled/decked too 9.00 studded standard bore 600.00
2 bolt high nickel 400 block standard bore 450.00
632 c.i. bbc dart 360 pro systems carb 1050 h.p ran 8.80@156 @3235 bowtie block 10.200 deck just freshened aluminum rods with 21 runs on them carb too pan new rings bearings/fresh hone new lifters 12000.00 have dyno sheets
doug 586-935-8780
Interested in all 4 of the welds. 10 holes, you mean draglites? If they are and in good condition I'll take all 4.
Ken
Ken
yes draglites my bad there dirty could use some polish on em but not junk they allso have tires on them but i wouldnt use the front/ they have flat spots
Doug- nice meeting you today- thanks for the parts. Hope to come out and watch some cars this summer.
:cheers:
Justin
