overdrive problem?
87cuttykid
i have a 350 turbo transmission and everytime i hit about 45 -50 mph it goes into overdrive and it keeps going in and out... so im trying to figure out why it keeps going in and out of overdrive? any answer would be appriciated..
thx a lot
thx a lot
Most likely what your feeling is the tcc apply. Attaching a older scan tool will tell you if its applying and releasing.
It's a 200-4r
If it's the original trans, it should be a OG coded 200-4r. The stock lock up solenoid in any 200-4r is JUNK (even if it's new oem). It could have a pressure switch problem as well (screwed into the valve body).
Does the speedo needle bounce at all?
Mike.
