well usually if it smells like gas, then your rings are worn as well, which is allowing oil to mix with the gas in the cylinders. Toss a can of that restore stuff in after your oil change and see if it helps. ive heard that stuff works decentlyWhen i go to change my oil i am able to fill 3/4 of a water jug. It also smells like gas is mixed with it. Does that trans fluid method actually work?
its called restoreWhat is the restore stuff called?
