Anthony said:yea, up to "L" in "NORMAL" then back to "N" then back to "L" you get the idea, not fast, but up and down
Anthony said:i have no drips under the truck.....ever. the stat didnt do it either. same deal.....cold! hahaha
Lon said:might be a vac line off under the hood.the flap that changes the heat from cold to hot runs off the engine vac
prostreet377 said:anthony does your temp gauge get hot so it is showing engine temp
