Here is a text to the engine ad, but I have a lot of pictures so it is just easier to link the Craigslist ad.
The only reason I am selling this engine is because I sold my Camaros and bought a Pantera. BUT, if someone has a nice rust free, 4 speed 69-75 Camaro, I may be interested in the car and will keep the engine....
Link to Craigslist ad...
https://detroit.craigslist.org/okl/pts/d/troy-new-350-chevy-engine-all-parts/7604781444.html
Ad text...
New 350 Chevy Engine - All Parts Including gaskets
All Machine Work Done - Nearly Ready to Assemble
Dart Aluminum Heads
Comp Cams Roller Cam and Lifters
Read entire ad for specifications...
80's Chevrolet 4 Bolt Main Block #14010207
($1,000 worth of machine work)
.040 Over - Bored and honed to pistons with torque plate
Line Bored
Decked
Baked and steel shot blasted - Looks like new
All New Parts mostly from Summit
Eagle Street Performance Rotating Assemblies with Speed Pro Pistons B13403E040
.040 over pistons - Balanced Assembly
All New Bearings - Rings came in Kit
Manley Timing Chain Set 73163
Manley Camshaft Thrust Buttons 42113
Manley Camshaft Lock Plates 42114
Champ Pans GM-Style Timing Covers CP136WS
Freeze Plugs - World Products Sportsman Parts Kits PBMBKSP
Blue Printed Melling Pump
All Fel-Pro Gaskets - 1 pc oil pan gasket
New Freeze Plugs
New ARP Head Bolts
Used Parts
Dart SHP Special High Performance Aluminum Cylinder Heads 126322 (Very low miles - Like new)
Dart Bare Head #127311
Combustion Chamber Volume (cc): - 64
Intake Runner Volume (cc): - 200cc
Intake Valve Diameter (in.): - 2.020 in.
Exhaust Valve Diameter (in.): - 1.600 in.
Spark Plug Style: - Straight
Maximum Valve Lift (in.): - 0.600 in.
Camshaft Style: - Hydraulic roller
Outside Diameter of Outer Spring (in.): - 1.437 in.
Retainer Material: - Steel
Lock Style: - 10 degree
Rocker Arm Nut Thread Size: - 3/8 in.-24
Guideplate Pushrod Size: - 5/16 in.
Intake and Exhaust Valve Angles: - 23
COMP Cams Magnum Retrofit Camshafts 12-430-8
Basic Operating RPM Range: - 2,000-5,500
Intake Duration at 050 inch Lift: - 224
Exhaust Duration at 050 inch Lift: - 224
Advertised Duration: 280 int./280 exh.
Valve Lift with 1.5 Factory Rocker Arm Ratio: - 0.525 int./0.525 exh.
Lobe Separation (degrees): - 110
$4,200
I will paint and finish assemble for $700 additional
Located in Troy, Mi
Ad text...
Dart Aluminum Heads
Line Bored
Decked
New Freeze Plugs
New ARP Head Bolts
Used Parts
$4,200
Located in Troy, Mi
