MALACHI
Ok, before any flaming happens, I already know I don't know what I'm doing. I fully expect to blow this up due to stupid mistakes.
Here is what I got.
1979 Foxbody
Was told it had a blown headgasket and just needed reassembly. yuk yuk yuk
Got it all torn down.
Heads were checked out and milled down and are good to go. GT40P w/matching headers, Offenhouser intake, Holley 750 DP. (yeah I know it is too big) I was told it was cam'd.
And then began the problems.............
Old engine was run with a bolt in the combustion chamber. it seems some moron thought it was ok to just upgrade the heads, and leave the banged up piston in it. So I went and got a piston/rod from Part Galore. (took apart a whole motor for just that.)
I then pulled the block. Holy crap. It looked like someone took copper pennies and laid them on the train tracks for bearings.
The rings were broken into so many pieces, almost none were unbroken. Once the pistons were all removed, I discovered that the block had a crack in a cylinder wall.
Then I pulled the cam.... 2 lifters were stuck and after cam was out I found that the cam was ruined. Comp Cam. About a .325 lift. Nothing too special. only 14 of the lifters would remotely servicable.
So I bought a replacement engine. an 87 from an old truck I beleive. Stock.
Currently have 1.6 SVO roller rockers for the heads.
Now here is where I get stupid. I am pretty sure this will be a roller motor given the year and type vehicle it came from. I have yet to tear t down, but presume it will have roller lifters in it?
I am looking to spend no more than $100-125 for a better aftermarket cam off Craigslist.
Does anyone have any input or advice that I might be able to use? Hell someone who can give me a hand would rock. Engine rebuild is happening in Madison Heights.
Other noes on the car: 5 speed, aluminum driveshaft, tied frame, notchback, fiber hood and trunk. (dings and rust were added free by the previous owner)
Here is what I got.
1979 Foxbody
