Need help with Bogging problem
chayes7203
New member
Hi I have a 92 gt. The problem is that every time I get ready to launch it it bogs out real bad. But once the rpms get up it's totally fine. I set the TPS to .98. The only thing I can think of is the maybe the c&l mass air meter is not calibrated right for the injectors. I believe they are lbs injectors and I don't know what the maf is set for. Will this cause my problem it runs fine when the rpms are up only bogs out on take off. I live in warren Mi If someone could come by and take a look at it that would be greatly appreciated.
