NEED HELP HOOKING UP!!!
red347lx
I HAVE AN 89 MUSTANG WITH A 347 IN IT HOOKED UP TO TH400. ALL NEW UPR SUSPENSION INCLUDING ANTI ROLL BAR, UPPER/LOWER ADJ. CONTROL ARMS, TORQUE BOXES ARE WELDED. PROBLEM IS I GET ON THE TRANS BRAKE AND LET IT LOOSE AND IT SMOKES THE TIRES BAD! I AM NOT A GENIUS ON SUSPENSION ADJUSTING. NEED ADVISE ON WHAT I CAN DO TO IMPROVE TIMES. TIRES ARE 27.5X10.5 PRESSURE AT 18LBS THANKS IN ADVANCE FOR SUGGESTIONS NATE
Who installed and set up the suspension? what's the pinion angle at?
do you have a good guess at the weight of the car?
need to know a few things befor I can help!
Street Legal Motorsports set up the suspension. They are going to adjust it hopefully Weddnesday at tnt at milan, but i was hoping to gegt it better for this weekend for the time being. I believe the pinion angle is at stock level. weght of the car is probably around 3000lbs(guessing). thanks for your help
From the website:
Team Z Motorsports is located at 27900 Hall Road in Flatrock, Michigan. You may stop by and visit the shop during normal business hours Monday through Friday. Use the map below for directions to Team Z.
E-mail Team Z Motorsports @ [email protected].
You may also call the shop at (734) 789-9540. If we don't answer, please leave a message. We're probably busy working on someone's project and will get back to you as soon as possible.
TEAM Z, I WENT BY YOUR PLACE TODAY TO TALK TO YOU ABOUT MY CAR, BUT NO ONE WAS THERE. CALL ME THURSDAY IF YOU ARENT BUSY AND I WOULD LIKE TO TALK TO YOU ABOUT DOING SOME STUFF FOR ME. POSSIBLY A CUSTOM CROSSMEMBER FOR A TH400 APPLICATION AND ALSO SOME OTHER ITEMS OF INTEREST. THANKS 734 341 2210 NATE
Suspension Install
Just to set the record straight Street Legal Motorsports did not install the suspension on Nate's car. Nate did buy the suspension parts from Street Legal but I did not install or adjust anything on this car.
I was out of town on business and I let Nate and a few of his friends use my personal garage to install the suspension kit.
You can’t just pull out onto a dusty road, bring your car up on the brake and expect the car to hook. Take it to the track, lower the tire pressure, make a few passes then you can start making adjustments.
Dave to your point on pinion angle, I asked the same question when Nate called me about his hooking problem. They never checked the pinion angle so that’s not a question that he can answer at this point.
Best Regards,
Shawn
