Need help ASAP v6 Camaro water pump
Mclovin
Doing a water pump on a friends car.. need to know the different torque specs for the water pump bolts and the order sequence.. The michigan E library is down so i cant look it up on chiltons..
There are 11 bolts. Starting above the rad hose connection and going clockwise.
1,2 192 inch lbs.
3,4 33 ft lbs.
5,6 192 inch lbs.
7,8,9 89 inch lbs.
10,11 33 ft lbs.
My Haynes does not show a sequence.
Hope this helps.
Kevin
1,2 192 inch lbs.
3,4 33 ft lbs.
5,6 192 inch lbs.
7,8,9 89 inch lbs.
10,11 33 ft lbs.
Hope this helps.
Kevin
Awesome thanks !
