wide winger
Motown's very own village idiot!
Well since the rail is about winterized, it's time for a long awaited 2G fuel system upgrade.
Plans are:
Get rid of the 2 section stock tank with the in-tank fuel pump set-up and replace it with a 12 gallon tank from Frontline Fabrications, little did I know it would take SIX months to have my order filled.
While I was ordering parts I added his drive shaft safety loop and a rear end diff cover.
The tank comes with AN -10 supply and -8 return line fittings, vent tube with check valve in case of a roll over.....God I hope I never use this feature!
The stock tank has two fuel level sensors in it, so I found out a FWD 2G only has one level sensor that has the same ohm scale as the two for the AWD tank, so I found one of them, now I can keep my stock fuel level gauge and it should work like.............. well a stock fuel gauge.
Another nice feature is the new tank will use the factory filler neck!
I'll install an Aeromotive Eliminator fuel pump to push the stuff through the -10 hose and into the injectors then -8 for return.
Aeromotive fuel pump speed control is going in for tame city driving and longer pump life.
Two fuel filters will be installed, one before the pump another ahead of the fuel rail.
The forever to get fuel tank:
Plans are:
