Systemax302
Okay, where to start, sorry this might be a little bit of a long read, but I need to gather some very educated information. The car is a 95 GT (5.0) w/ a 5 speed (t5). The Trans is factory stock to the best of my knowledge and if this is true it would have about 55k miles on it. The car has a small blower and bolt ons and its making 280 RWHP and 320 ft/lbs of torque, so it is making roughly 100HP over stock. The car has really never been driven really hard and/or drag raced and its never been on anything besides street tires. No drag radials or slicks.
THE PROBLEM(s)
This started mainly a couple days ago pretty much right after the car was lowered. Car got new shocks and struts all around and an Eibach Pro Kit.
Shortly after, probably within 10 miles of driving I noticed a clunking/popping sound coming from the rear of the car. At cruising speed its fine and even downshifting and hard acceleration seems fine and business as usual to me and I notice everything w/ my car. This occurs when starting in first gear and when going over a bump at low speeds say like the edge of a driveway. Also if you let the car coast in low gear at low speed and it will naturally want to kind of buck a little it seems harder than usual, louder, and feels like its more loose and sloppy in the back. Also when your coming to a complete stop when the weight of the car shifts you can feel it in the rearend. All the gears in the trans work, but the trans does have some buzzing sounds coming from it intermittently, mainly while coasting in 5th gear and the 4th gear synchro isn't perfect anymore either.
WHAT I TRIED TODAY
I first hoped maybe there was a suspension component loose from the install, but I went through the whole suspension today and there was nothing loose or out of place. There is some play in the driveshaft and when I move it by hand I can hear the clunking/popping sound Im hearing while starting in first gear so Im pretty positive this is the cause of the noise. You also can hear the noise from the center of the vehicle when pushing in on the top outside edge of the rear tires while the car is sitting on the ground.
QUESTIONS
Is the car alright to drive? What are the potential risks?
What do YOU think the issue is? Driveshaft? DS yoke? Rear end?
What do you think the best long term solution to this is?
Feel free to post up any and all information you have about this. I need all the help I can get at this point
ow:
THE PROBLEM(s)
WHAT I TRIED TODAY
QUESTIONS
