mustang guys/control arms questions
riche
Looking to get some new control arms for my 1992 fox. Right now I have upr double adjust. upper and adjust lower with solid ends. These are way too noisy and hard on the car being a conv. Just looking for advise and what you guys have and if you are happy with the product. I was thinking on going back to more of a stock upper with rubber bushings and a good lower. What do you think? Any help is great.
Rich
I have the Mega bite Jr. lowers and uppers and they are great. Look in the classified section someon is selling both upper and lowers for $150. Considering the lowers alone are like $300 I would jump on them!
I have the upr's like you on my car right now and they suck to drive on but my car hits the track a lot so I suffer with them.
I used to use Mega Bite Jr lower arms and stock uppers and had great luck. I had the jr lowers, stock uppers, eibach drag launch springs with an air bag in the right rear and the car would 60' low 1.4's on a pretty normal basis and went high 1.3's a few times. If I had a driver again I would use the same set up, maybe just switch out the upper rubber bushings for some poly ones.
I have mega bite but selling those to get some dbl adj uppers and lowers
Mine are good for street driving, I want to hit he track more this year. Mega bites are some good street ones.
Going to try the stock uppers again with pro3 lowers, basically the same and maximum motorsports lowers. Being a conv. I don't want to run poly in the uppers since it is too hard on the chassis. I guess that we will see what happens.
