mustang/ford parts for sale
THOR84GT
Assembled shortblock .30 over factory rebuild pistons, small flat tappet cam, arp main bolts, chrome oil pan, windage tray, newer double roller timing chain -SOLD
New 14" K&N X-treme air filter assembly -SOLD
NIB 9" K&N X-treme air filter(no base though) $40-sale pending
Aeromotive carb fuel pressure regulator$40
New Trickflow 5/16 pushrods 7.05" long $20
Trickflow 3/8 pushrods 9.00" long barely any run time
$40
Trickflow-R stud girdle $50
HPM mega bite jr lower control arms, barely used have just been installed on a project for a few years -$100
TRW 30 over domed for a 302 on recond rods with ARP bolts -$150
SSM rear upper control arms -$50
ASP Crank underdrive pulley -$10
Thor 734-637-3547 you can call, text or pm me
I have a ton more parts to add and can get pics
March steel crank underdrive pulley 79-93 powder coating is pealing a little bit $10
more pics
new melling 302 oil pump $5
87-93 hatch q-windows $40
wire looms $10
-10 fuel filter stainless 100micron element SOLD
Can I get a pic of the radiator? Where are you located at?
Thanks
Sent from my ADR6300 using Tapatalk
more pics and parts
Trans cooler has -6 ends, trans lines do not come with it $25
sbf water neck new just taken out of plastic for pic $5
adjustable dual feed for carb -6
$10
7/16 5 lug spacers all 4 of them $10
6 disc in-dash changer out of a 07 F-150 like new
$100
NEW 9" K&N Xtreme air filter no base for it though was going to use it on an air pan is the reason for no base $40 -SALE PENDING
NEW 14" K&N Xtreme air filter assembly top bottom and plastic ring drop base -SOLD
thor i might want that trans cooler, i gotta double check with 1badford to see if im getting his or not
thor i need the trans cooler if dudek doesnt pick it up.... mine jus startd leakin
lmk asap.. thanks chris 734 286 1016
