What size did you run in your notch? and what temp did it run at?
I still have all the A/C parts on the car. Could the A/C condenser having bent fins or something to make it overheat? It seems like my problem is air temp sensitive. Since its been cooler out and i have been running the car without the thermostat, it has stayed cool under normal driving and playing a little.Though it seems like it runs too cool.
But when i had the thermostat out and it was an 80 degree day, it stayed cool for 20mins then it wanted to heat up a little to around the ideal temp, but kept rising. I know its bad to drive without a thermostat but i dont want to keep the heat on to drive the car. Still trying to figure this out, and i would like to keep the a/c components there.
Only a few of the fins are bent. Im not sure of where the radiator cap is located on this system. Normally they are on the radiator but it seems as if it has a different setup. Ill take a picture of it and post it.
Ok, it does have the cap it was covered by some blue aftermarket dress up peice. Is there a way to test a cap to see if it still holds pressure? If the cap was bad, wouldnt it spew coolant out of it or boil the overflow? because i have no coolant loss and the overflow is fine.
What about if the alternator is bad? If the fan isnt recieving enough voltage to spin at the speed its sopposed to? When the car is warmed up the volt gauge is between the "O" and "R" of normal. But the fan still does come on high.
