muscle car stuff & perf parts....need this stuff gone!!!
DarkoStoj
garage is too cluttered, buy this stuff NOW!
1 new set of edelbrock chrome valve covers for big block chevy $30
m/t aluminum finned valve covers for sbc $30
18x8 konig trouble wheels for a ford bolt pattern 5x4.5. 6" backspacing, fits newer fords and mustangs $200
aeromotive gas tank sump in new 1967 camaro gas tank $125
competition engineering gas tank sump $30
1 set of 993 casting sbc heads. I used them on my blower motor to drop the compression..also the exhaust ports have been opening up. Cleaned up with comp cams valve springs, ready to bolt on $200
holley 80575s 600cfm mechanical secondary blower carbs. Cost me $750 each. They are in like new condition $1000
11" heavy clutch off a chevy with 10 spline 1 1/8 input shaft, plenty of meat left $35
chevy 350 4 bolt main shortblock $125 (have 2 of these) would rebuild, but just came out of a running car std bore, complete
rear bumper cover and taillight panel out of a 93ish camaro, lighter metallic blue color $75
new stamped chrome small block ford valve covers $40
1967 camaro upper cowl, great shape $35
brand new leaf springs for 1965 to 1973 mustang $200
1991 corvette c4 complete passenger door $75
1 brand new set of sce self sealing copper head gaskets for a sbc 350 .030 $100
1 brand new set of flat out gaskets rubber coated copper head gaskets for sbc $100
sbf 302 timing gear drive new in box, $60
chevy straight 6 with 4 speed manual trans, looks nice, manual trans complete $200
complete front drum brake setup with spindles off a 1967 camaro, these actually worked very well in my car, but upgraded to discs $60
COMPLETE 1988 porsche 944 wiring harness, chassi and motor, everything uncut, $100
chevy 350 flywheel $50
chevy 350 flex plates $35 each
billet aluminum 28oz imbalance flywheel for small block ford(can change imbalance to 0 or 50oz) only has engine break in time on it $300
ford 9" 3rd member gear unknown open diff $50
ford 9" 8" axleshafts for 1967 to 1973 mustang with a 8" or 9" 28 spline $100
nice new looking power brake booster and master cylinder for fox body mustang $50
67 68 mustang fastback fiberglass eleanor gone in 60 seconds scoops upper and lower $200 new in packaging
porsche 944 sunroof, red good shape $125
248-506-5916 [email protected]
NEED THIS STUFF GONE!!!!!
