firebird355
I have a motor and tranny for sale it is a 306 sbf and a c4. Transmission
Start with transfer it is. 70 or newer c4 it has a tci manual reverse pattern valve body red line racing clutches a tci bellhousing and a brand new Bdr racing Converter it is a 4200 to 4500 stall with antiballiong plates has maybe 30 miles on it and trans less than athousand miles
And the motor is a dss racing pro bullet 306 with the main support. System
It is a pump gas motor compression ratio is 10.5/1
It has pro topline aluminum heads that I bought from livernois 180 CC with 58cc chambers
Has proform aluminum roller rockers comp came lifters and pushrods
Camshaft is trickflow stage 3 574/595 lift duration at 50 is 236/248. Lobe Sep is 110
Has a Victor Jr intake manifold on it
Canton oil pan and pick up
Also have poly motor mounts and trans mount
And Hooker supercomp headers inch and three quater primarys and 3 inch collecters and full exausht 3 inch
I'm going to keep Carb and distributor and alternator brackets
Motor and trans are in good working order and still in my fox body so can hear run/drive
$3000 takes it all in the car know not pulling till I have it sold so anyone can hear it run
I can answer any questions. Call me 810-423-1194 thanks Joe
I am willing seperate parts call me to discuss prices
