my89notchback
I am swapping the power brakes to a manual set up and need to know if you use the proportioning block or change to a in-line valve? The car is going to stay a disc front/drum rear set up.
Thanks!
Thanks!
Ya,I moved the pin up like 1.25". Shit its been so long.
You can also use a G body brake switch and make a simple bracket to hold it. It's an in out switch for the brake lights with adjustable threads all teh way down the switch so you can adjust depth. I hate putting anything extra in the brake lines, plus you can just use spade connectors and not relocate the wiring for the brake lights.
Never once had an issue with the pressure switch. It was like $10. Wired right up. Just my $.00000000002
Ryan, did you just T it off the master? Like between the master and the line lock? I have a oil pressure switch from a fuel pump left over. Would that work? Or do I need one of the Autometer pro light switches?
Did you guys pull the whole pedal assy or were you some how able just to remove the brake one, to move it up a 1 1/2
