Fryguy302
Local cash and carry sale is preferred on everything and mandatory on large items.
Fox body S-Trim kit, passenger side, $1300obo or trade
TCI PRO-X Converter for 1200-1500hp supercharged small block (brand new in box) $850obo
Bennett custom solid roller blower cam for SBF, 272/286 @ .050", .726/.720 lift w/ 1.6s $200
(8) Used custom diamond coated pistons for 434ci, 9.5 deck SBF set up for big boost. Bore Size: Piston is 4.130, Comp. Height: 1.229, Pin size: .990 (pins not included), Top ring is .305" down, $250 for all!
L33 (aluminum 5.3) LS for sale, complete good shortblock with 317 heads, DOD is bad but motor ran strong, $1k
S500 Turbo, Bullseye race cover, 104mm compressor, big power, very, very little use (3 aborted passes since brand new), $1k
Hurst shifter for T-5, used, $60
T5 bellhousing for FOX v8 car, $30
Clutch and pressure plate assembly for FOX 5.0 mustangs, decent shape, have three of them at $35 each
Underdrive SBF crank pulleys, $25 each
Weldon Fuel Pressure Regulator, great shape, $100
XS Power 16v batteries, work good, used, $50 each
Old school slot mag wheels, (pair of them), 15", $80
1969 Camaro seats, front buckets and rear bench, fronts need to be recovered, complete with rails, currently green, $400
Some pics on craigslist:
https://detroit.craigslist.org/okl/pts/d/fox-vortech-alum-60-s500/6419516443.html
