Uthinkso
My wife ran to the Horton's for coffee this morning and upon return wasn't able to remove the key from the ignition. She told me that this has happened before and she just puts it back in gear and slams into park (floor shifter) and then it releases the key. I went outside and ran it through all the basic, turn the wheel, start it and put it in gear business and the key is stuck in the ignition.
Before I get too far, I'll mention that is a 99 GMC Jimmy. My guess is that the park lock solenoid either has failed or isn't getting sufficient voltage or ground. Just as a potential quick fix, I'm going to clean the battery contacts as I've seen certain solenoids flake out before due to bad contact at the battery.
Anyone else have any ideas? TIA
