Mass air flow for 24# injectors
2MANYMUSTANGS
I have a 90 LX 5.0 It is built but nothing too crazy - 325 -350ish HP. I have 24# injectors but need a matching mass air flow meter.
Ford 21lb injectors (high) #s: D9B, F65E (305/350 GM)
Ford 22lb injectors (high) #s: FOTE-D9B (vettes and range rovers)
Ford 23lb injectors (high) #s: F7TE, F8TE (7.5L truck)
Ford 24lb injectors (high) #s: F5DE, F1TZ, F2LE, F2LE-9F593-B2A, FMS-M-9593-A302
Ford 24lb injectors Ford 93-95 Mustang Cobra
Ford 24lb injectors 93-01 Lincoln Mark 8
Ford 24lb injectors 95-up Lincoln Continental DOHC 4.6
Ford 24lb injectors 88-97 EFI 460's F250-450 & E250-450
Ford 24lb injectors F350 with V10
Ford 24lb injectors Lincoln Aviator 4.6 DOHC
Ford 24lb injectors Lincoln Navigator 5.4 DOHC
26lb '00 LS1 F body, maybe '99 to?, same as Ford 24's
Ford 30lb injectors (high) #s: E9SE, F1SE, F1SE-E1A (3.8SC and SuperCoupes)
Ford 30lb injectors: 95/96 Ford 4.0L Explorer & Ranger & Other
Ford 30lb injectors: 89-93 SuperCoupe
Ford 36lb injectors: 94-95 SuperCoupe
Ford 39lb 03-04 Cobra
Ford 42lb 99+ Lightning
heres a list i found...i know u only asked about the 24's but the list looks good here. maybe use the mass airflow off one of these stock 24# injector models if it will plug into ur harness
Wow! Very cool! I am going to save this information into my stash of car data.
I actually have a MAF from a mid 90's Cobra. Not sure if my harness will plug into the connector. I know the flange is different than what I have. I'll check the part number. Maybe I can swap the internals.
Hate to burst your bubbles guys but stock Ford MAFS are not calibrated for any injector in particular, rather the eec is programmed with the injector data and the maf transfer of the particular maf it was originally matched with. Only aftermarket mafs are "calibrated" The Cobra maf will most likely plug in but it's probably at most only capable of about only 14kgs/hr more than the stocker and due to the combination of the larger than stock injectors and it's "higher" transfer would result in it running rather rich.
EDIT: Now having said that, who ran 24# injectors with a 70MM Cobra eBay maf for years blindly? This guy did before knowing any better :tongue:
on a side note to something i do know tho.if you have or can find any type of Pro-m mass air unit (newer ones or the older ones..they had different names through the years), you can send it to them no matter what model it is and they will calibrate it to what you want for 100$.
