BIGCOWL-IMP
Well i was thinking of building a 2nd motor but can`t do it at this time. I`m in Mi. 48336
LS3 block with rear cover and flex plate. $900 .
New ls3 crank from crate motor $100
LS truck oil pan with pick up and dipstick and tube.$50
New ls3 vett oil pan, pick up,oil filter and dip stick and tube $SOLD
LS9 heads....same as L92 heads but have titanium valves and i have a set of the yellow 918 valve springs and hardware that can go with them $SOLD They might have 50 miles on them with no problems.
LS7 parts are new from a crate motor
LS7 dry sump oil pan, pick up, windage tray $200
LS7 oil pump $250
LS7 water pump SOLD
LS7 front cover ?
LS7 pulley balencer $150
Also have ls3/l92 lifters, push rods, valves, valves springs.........
lifters=$60.00
push rods $25
Stock l92 valves sold
Stock valve springs free with valves. You will also recieve 4 free extra valves and hardware.
Also have what think is a alternater bracket from the trucks with ls3/l92 motors.
Flex plate spacer.....$30
Front cover sensor with bracket. $?
Truck oil pan with pick up and dip stick and tube. $50
Also have polished LS7 exhust manifolds with the exit flange.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MESELX:IT&item=220406438581
LS7 oil pump $250
LS7 water pump SOLD
LS7 front cover ?
lifters=$60.00
push rods $25
