Can anyone recommend a tuner in South East Michigan for a good turbo tune? Been a long time lurker here but usually post over at some of the other boards.
I just picked up a 2005 Sierra Denali with a forged 370 with a Livernois tubular turbo kit and a HP71 turbo.
It's currently running a 4L80E with the AWD. I know HP Tuners handled the segment swap for the tune for the 4L80E and that it is currently running a speed density custom 2-bar OS from HPTuners that was done by Speed Inc. The guy I bought it from said there were a few quirks in the tune and that I should get it checked out.
It's currently pushing 9psi with current spring in the wastegate and I'm seeing 10.0~10.2 afr at partial throttle and 10.8~11.2 afr at WOT. The guy I bought it from said the tune was done at about 13~14psi on a stock motor and a PT70GTS (before they blew up, motor popped a piston and took out the turbo). Sounds like nothing was changed in the tune for the new turbo and forged 370.
I'll be swapping it to a 4wd transfer case so I can lock it in 2WD to get the tuning done on a dyno. Also plan on adding a boost controller before I go in for the tune as well.
Looking for a tuner that will actually go through the tune, get idle, partial throttle, and WOT all spot on and not just a PE table rape like my last four tunes. From what I've found so far, my top three picks in no particular order are: Baker Engineering in Grand Rapids, Sean at C.A.R.S. and Lidio over at Alternative. Lidio is by far the most convenient since I'm only a few minutes from his shop but it seems like he is mostly a Mustang shop, but I'm willing to drive for a good tuner.
