LS 6.0 parts
kip_b
6.0 parts
stock stroke with 4.010 bore grp aluminim rods and diamond pistons.
have block but cracked between coolant passages but has arp main studs..
243 ported heads off 06 trail blazer(havent been ran since ported)
crank is out of 06 trail blazer but needs turned spun rod
a set of solid n hyd lifters..
everything has less than 20 passes.
make offer not looking for much just want it gone..
What would you take for the front cover, rear cover, and valley cover if those are available? Thanks!
If so, any chance you also have a set of center bolt valve covers as well?
