lots of parts
1bad Lad
Hey guys tryin to clear out the basement
- driveshaft loop for 82-02 fbody 25$
- Je pistons 4.030 bore these r for an ls engine fit 6.0 iron block big dish for big boost apps 600$
- 6in eagle rod and srp piston used only 1500miles good to go 500$
- Lt1 block with splay caps 300$ or 750$ for rods piston block
- turnonetics delta waste gate 75$
- 3.8 v6 iron heads fresh valve job fresh cut valves deck resurfaced ls6 valve springs new seals decks have surface rust easily cleanable and runable 300$
-kenny brown subframe connectors for fbody used 50$
-edelbrock longtube headers for 98-02 fbody 1 3/4 step to 1 7/8 needs one collector 200$
- 6.0l truck intake manifold with fuel rails and injectors 100$
- set of ls7 heads fully cnc with new valves new valve job and fresh deck 3500$ add 300 for dual spring kit or whatever spring u desire
- set 243 ls6/ls2 heads full cnc with 2.02 1.575 stainless valves ran on car for 2000miles i am having them refreshed so theyll be like brand new 1000$without springs will come with new seals lemme know what springs u need i can get em for additional cost
