Dart331Stroker
Lots of misc new and slightly used parts for sale, some are left from upgrades, some from project that is now cancelled...
14" Black Chrome Chevrolet Air Cleaner with Bowtie wing nut, comes with NEW Barry Grant Rush 14x5" air cleaner. This item has just sat in my garage, great shape. Chevrolet letters are red, these things on Ebay sell for $60.00 without the reusable filters. $50.00
Black powder coated aluminum SBC valve covers, comes with black breather with Bowtie logo, and 12 aluminum black chrome t bars. $50.00
18" Derale 2200 CFM electric fan, NEW puller style. with hardware. $100.00
Barry Grant Speed Demon carb with line kit, NEW IN BOX, part number 1402020 over $500.00 not including line, your price $400.00 with line.
Barry Grant High volume mechanical fuel pump, new in box, #8 inlets $60.00
Melling SBC 10550 oil pump with shaft $50.00
Melling SBC M-55HV pump 20.00
Melling screens for SBC $5.00 each (3)
Clevite 663-P std rod bearings for SBC $24.00
Clevite 663-H std rod bearings for SBC $60.00 with one extra rods worth
Clevite MS 590H mains standard $50.00
Clevite MS-909P mains standard $20.00
Roller thrust button with cam lock plate for Chevy $10.00 NEW
Aluminum alternator pulley, with fan, and snout cover used for serpentine belt use, used on SBC and MY SBF. $20.00
Cloyes dual row timing chain set C-3023XS-P NEW V- 78-86 V8 55-91
$20.00
Chrome coil bracket for round coil $5.00
Factory aluminun power by ford valve covers $40.00
Orange tall SBC powder coated aluminum valve covers $20.00
13 gold t bars $.25 each
6 red t bars $.25 each
4 chrome t bars $.25 each
SBC Webster stud girdles new. $40.00
16 Factory style SBF Hyd roller pushrods, NEW replacement items, upgrading your rockers change them while you are there, $20.00 for the WHOLE SET
Private label Blue Ford 1.6 ratio 3/8 stud rocker arms, used on my 331 for about 3 months upgraded to shaft system on my car. $50.00
Mallory 4207 regulators, one inlet two outs, plus gauge port, one has two fittings out already installed, and the other has one. $30.00 each
Nitrous works 10010 kit NEW with Nitrous pressure gauge, extra bottle nut, and gauge adapter. $350.00, this is a GREAT DEAL
14" chrome air cleaner lid only, rounded top style $5.00, replace your rusty one. $5.00
CSR 1/2 water outlet fitting, can be used on Water neck, $5.00
Mallory RPM activated switches 627 A, three available, $20.00 each
Mallory 3 stage high speed retard 618-3 $40.00
350 block, std bore, 2 bolt mains, 39700010, comes with used parts that were removed from the block. Chrome timing cover, balancer, crank, rods, pistons, and oil pan. $50.00
Melling flat tappet hyd cam, 422 444 lift and 204 214 @.050 duration, good rv, truck, or cruiser cam, with lifters and lube, NEW IN BOX. $60.00
6' blue push lock line -8 (1/2) line $5.00
several fittings: BG y block with 1/2 inlets, comes with one 1/2 x -8 male fitting, BG -8 carb fittings, 2 -6 60° hose ends, 2 1/2 -6 fittings male, 4 -8 30° hose ends, 4 3/8 x -8 pipe fittings, 1 1/2 x -6 pipe fitting, BG 15lb fuel pressure gauge, -8 90° hose end push lock, -6 45° push lock hose end, 1/2 x -10 male fitting, -8 45° push lock hose end, 1/2 x -8 male fitting, 3/8 x -8 45° male fitting, -6 hose end straight, -8 hose end straight.
MSD blaster IIF coil, for fords with duraspark type plug, I am including the plug with it also, took off my 1983 GT. The coil was used for about 2 weeks, I acquired a complete NEW MSD system I put in its place. $30.00
Email me at [email protected], or call me.
If you miss me on the phone please leave a message. I was recently laid off, and have been in the performance industry for over 20 years, I know what this stuff is worth, but want to offer you some deals.
You can call me at 586-946-0078, leave a message, out looking for work, and doing interviews, so I may miss you.
Thanks
John
586-946-0078
[email protected]
Oh I have pics, but you can also see most of them or get descriptions on jegs, and summit.
Thanks
$20.00
Thanks
John
586-946-0078
[email protected]
Thanks
