Superman09
We sold the building I am currently using and with my current Autorama Trans Am project, I am unsure if I will get to finish the set-up. The sleeper set-up was just going to be used this year and I already have someone who wants to use the roller for a more drag only set-up as it should be!
Here is what I have for sale!
Circle D Pro Series Multi Disk 3C Converter
-Sold
Melling 10295 Oil Pump. Brand new in the box.
$100
PA Racing Body Mounted Tq. Arm
-Black powder coated. Built to mate to a stock rear end. Ran in my Trans Am last year. Comes with Tq Arm and chassis mount.
$275
60# Siemens Deka EV1 Injectors
-SOLD
Brand New Magnaflow Catback for 98-02 LS1 Car. Brand new, never been bolted up or installed. All hardware included. Dual Single tips.
$450
LS6 EGR Equipped Intake Manifold. Fuel Rail, injectors, and TB NOT included. Intake only.
$335
LS1 Water-pump.
$50
LS1 Power Steering Pump. Couple chips in the pulley but no issues. (Fittings for the aftermarket PS lines not included) Can include the Power Steering line kit for $145 however.
$50
LS1 Starter.
-Sold
LS1 Clamshells with Poly Mounts installed.
$75
10-bolt rear end. 3.23 gears. Has fresh pads and drilled/slotted rotors attached. Also have LCA Relocation brackets installed! Never had any issues, never made noise, etc!
$275 picked up
LS1 Driveshaft. Zero issues, removed when swapping to 400-9" combo.
-Sold
LS1 Front spindles w/ hubs, speed sensors, drilled/slotted rotors, fresh pads, calipers.
$250 for the pair
All prices are picked up, cash only, in Port Huron. Thanks!
-Sold
$100
$275
-SOLD
$450
$335
LS1 Water-pump.
$50
$50
LS1 Starter.
-Sold
$75
$275 picked up
-Sold
$250 for the pair
