beesbadstang
. Mallory EFI external tank fuel pump less than 50 miles on it. Part # 5110FI
. Autometer 2-5/8 liquid filled EFI fuel pressure gauge 0-100 psi in great shape 40$ 0b0
. Rear air bag that goes in the spring 20$ obo
. Cold fusion EFI wet nitrous kit 125-200hp ( solenoids , lines, micro switch, jets, solenoid mounts, EFI spray nozzle, only thing missing is the nx line from bottle to the solenoid. Bottle needs to be serviced due to a leaky valve. Bottle holds pressure but bleeds down after it sits for a long period of time. 175$ obo
. Lakewood clutch fork for a lakewood bell on a ford T5 or Tremec trans ( 1'' longer than stock) part#15525) 30$ obo
.Complete rear sn-95 cobra brake kit ( calipers, pads, brake lines, two sets of rotors one is cross drilled and slotted with very low miles and the other are stock. MAKE OFFER..
.Currie brake adapter plates that mount the cobra brakes to the Big bearing( torino style) bearing end. MAKE OFFER...
All parts are used but have very little miles, If you have any questions or need pics shoot me a message and I will get them to you.
