JT351
Hi everyone,
Ok here is the deal, I've been trying to set up a 3.73 in my red car for almost 5 days now.
issed:I am no stranger to setting up gears, I've even done the 4.10 in theThunderstang. No matter what I change, pinion depth or lash I still get the same pattern. Tight lash loose lash it does not seem to make a difference. Anyone else experience this? It is a used gear, is there anything I should know about using a used gear? I checked before installing it and did not see any unusual wear pattern. The other thing I'm wondering is I believe this came out of an 8.8 independant rear suspension expedition. Are those gears different? Any help would be great and thanks in advance.
JT
JT
