99SaleenSpeedster
I posted photos quite a while back of our development 5.0L head and our stage 1 head is now ready for release. We are currently working on stage 2 and stage 3 heads, which will be a separate port design and include upgraded hardware and be available shortly.
All of our cylinder head development, flow work, and cnc machining is done in-house at our Dearborn Heights facility.
Cores are not readily available at this point, so a customer supplied head would be required. They can be sent fully assembled or disassembled.
A) Customer supplied heads sent bare and clean - $899.00/pr. + shipping.
CNC ONLY (for optimum flow, we highly recommend a valve job and custom ground valves). For an additional $100.00, we can disassemble and return to customer bare with all associated parts.
B) Customer supplied heads sent fully assembled or bare (with all associated parts) - $1,299.00/pr. + shipping.
Thank you
Regards,
Rick LeBlanc
Livernois Motorsports
- 5 axis CNC machining
- Custom CNC valve job
- Custom ground factory intake valves
- Custom ground factory exhaust valves
- OEM valve seals, locks, retainers, and valve springs
- Cleaned and assembled w/o camshafts
Thank you
Regards,
Rick LeBlanc
