Lincoln Precision Tig 375 Ready-Pak (440A Max) Welder
LT1Pat
Well-known member
Works perfect and comes with everything but the argon tank. I will still be using this up until the point that it sells. I may trade for a smaller inverter welder.
http://www.lincolnelectric.com/en-us/Equipment/Pages/product.aspx?product=K2624-1
The Power To Perform![SUP]SM[/SUP]
With Micro-Start™ II Technology, and our new and improved AC Auto Balance®, builtin Advanced Control Panel, and Power Factor Correction on board, the Precision TIG® 375 delivers the Power To Perform!SM
  • Patented Micro-Start™ II Technology - Delivers extremely stable low amperage starting, welding and cratering for both AC and DC welding.
  • Selectable welding modes - Such as high frequency, scratch start, and Touch Start TIG®.
  • High duty cycles - 375 amps at 40% duty cycle.
  • Widest welding range in its class - 2-420 amps for both AC and DC.
  • Advanced Control Panel - TIG pulser allows you to control heat input for any weld.
  • Standard power factor correction capacitors - Lower input currents when welding at higher output.
  • Excellent stick welder - Even with Fleetweld® 5P (E6010) with new Automatic Hot Start™ and Auto Adaptive Arc Force™ controls.
  • 115 volt auxiliary power receptacles - Great for powering an optional water cooler or power tools.
  • Add an optional Under-Cooler Cart - For extra storage and water-cooled applications.
  • Built-in storage compartment - For torch consumables.
  • Water-cooled torch connections with no adapters required - Side mounted, out of the way, and well protected.
$4500 OBO
