Light Problems
NTAHORS
on a 1998 Mustang, that was in a mild frontal/right crash. The Turn Signals, Hazzards, and Brake Lights do not work. all fuses are good, wiring was not damaged from the crash. I tried a new flasher just for the hell of it. I was thinking possibly the multi-function switch. The wipers,washers, and High beams work. but I am wondering if the there could be a short in the turn/hazzard circut of the switch. I believe that the brake switch signal runs through the MF switch which is what has lead me to belive the switch may be the culprit.
Thank You
- Corey
Just Looking For Opinions..
normally the chmsl will work when the MF switch is bad because it should be wired directly from the BOO switch
