cobrarwanab
I am about to start my cage install and found an issue whal checking for chassis straightness. Laid down my chassis center line and took measurements from a few symmetrical checkpoints on my frame and suspension. All the measurements were equal from side to side when measuring from frame check point to C/L. But when i measured from my rear sway bar mount hole to C/L I got a 1/2in difference from side to side. I still have to make sure the sway bar mount plates on my lca,s are welded square And take a few more measurements off my rear housing to insure rearend straightness but does anybody have any thoughts on correcting this issue?
