In need of a 50 inch driveshaft
Need more specifics, 50" from where? I usually measure from the seal to the center of the rear u-joint on the rear axle. You can also take the old slip yoke and insert it all the way in until it bottoms out, pull it out 1 inch and measure center to center. Also what series u-joint on the rear axle?
