bigg Club Member Apr 6, 2009 #1 ok , i put coil overs on the S-10 last year and i think i need a bump steer set-up..my truck has the stock type manual steering.. when i hit bumps in the road it kinda jerks around a little any suggestions on a brand ? any info would be great ,
avbcon12 Club Member Apr 6, 2009 #2 use a bumpsteer gauge to determine if a kit is needed or not before you go spending money you might not have to
bigg Club Member Apr 6, 2009 #3 i think i mite have the springs tightened a little much , to clear the headers..which is giving me the shake when i hit bumps
1BADAIR Club Member Apr 6, 2009 #4 how is the idler arm? the tie rods and relay rod should normally be a straight line. Last edited: Apr 6, 2009
bigg Club Member Apr 6, 2009 #7 1BADAIR said: are you still using stock spindles ? Click to expand... yes
