first u need to get ur heads flowed so u can get an intake to exhaust flow ratio. then yes on blower engines u want a 112-114 separation and u definately want more exhaust duration. if ur heads are in the 60s percent range intake to exhaust flow ratio then get a cam with 10-16 degrees more exhaust duration. if ur in the mid 70's ratio then something like 7-10 more degrees on the exhaust. even if the heads have a i/e ratio in the 80's i would still go with atleast 6-10 degrees more exhaust especially if u plan on runnin a good amount of boost. then if u get a flow curve u will know how much lift u will need on ur camshaft. and personally i would get something with about .020 more lift than what the head peak flows...just my 2 cents. u need to have as much exhaust flow as possible to take pressure off the pistons i would prolly the cam installed at a 110-114 centerline for a blow car....depending on how high u wanna rev it and where u want ur power band to be at!!!!!!!!
