Holley Power Valve Selection?
cobrarwanab
How do you select the correct power valve? I bought a used 650 DP. I cleaned it up and installed a rebuild kit. i replaced the power valve with the same that was removed. My issue is at idol the exhaust smells like shit and will burn your eyes. I adjusted the mixture screws to achieve max vacuum. Could the power valve be the root of my problem?
