Birdie2000
What kind of power losses typically are seen through the newer high-flow catalytic converters? I've heard that the losses are actually pretty minimal if you buy decent ones.
If it is for a near stock engine give me the camspec and I will let you know if the cats can tolerate it.
TFS stage 1 cam on a blown 302
Duration @ .050" (degrees) - 221 intake/225 exhaust
Cam Lift (intake/exhaust) - .312"/.319"
Lift w/ 1.6 rocker (intake/exhaust) - .499"/.510"
Lobe seperation (degrees) - 112
what 3" cat (very small size) will work?
thanks
this is just the forum i need because spraying my car has destroyed my cat and i was going to put in a bullet style high flow soon but not to sure what i want to do yet
so just go with no cat at all? because right now i have no muffler just straight pipe so maybe take out the cat and do a muffler to tone it down
