INJCTED
Help on turbo sizing
Hey guys
My dad is looking into turboing his Galaxie. I need some help with sizing.
Here is the spec on the motor
390 FE, it has edelbrock aluminum cylinder heads,
8.7 to 1 compression, mild roller cam
The goal is 550-600 to the ground would like to see full boost in by 2500, and
redline at 6250.
I have a HX-55 I got from a member on here. From doing some research its to small for my 408w
Im hoping since it hp goal is a lot lower than mine and its not as.
here are the specs
Compressor
Inducer 66mm
Exducer 98mm
It has a 4.25 inlet with a 2.25 discharge
Turbine
Inducer 84 mm
Exducer 70
It has a T4i flange (so close in size to a T4 flange) and about a 3.5ish dp
Hey guys
redline at 6250.
here are the specs
Compressor
Inducer 66mm
Exducer 98mm
Turbine
Inducer 84 mm
Exducer 70
