SuperStang90
I recently noticed my car smoking white smoke intermittently, like on a cold start after the car has sat for quite some time. Like 1-2+ weeks. It will smoke, and you can definitely smell in the garage that it is coolant. There isn't any coolant in the oil. The car runs great, and strong still. Whatever has happened seems to not affect performance whatsoever. The car doesn't overheat, and once the engine warms up after seeing the smoke it completely clears up. If I take the car out for a ride and pull it back into the garage I can still sometimes smell coolant. Could it be an intake gasket leaking coolant into the cylinders? I'm not positive that this is even possible but hey it would be easier then throwing head gaskets in it.. I have not done a compression or leakdown test, nor pressurized the cooling system yet. Figured someone on here may have some advice before I start tearing into it
