What do you guys use? What do you like or dislike about your set up? Is it as simple as , take a spring out and put the new one in or do they need to be set up? I'm going both for looks and handling but focused more on the handling.
There are a bunch of ways to go about it. In short, if you want a good handling auto-x or road course setup that is still very streetable I would go with the Strano Performance springs and a good quality shock like koni or billstien. His springs are a 1.25" drop which allows for great looks and great handling (near perfect roll center). They are 550lb fronts and 150lb rears (linear rate). I run that setup on Koni yellow's and it works great. Accompanied by 35mm front and 22mm rear bars. It has won a few Nasa Time Trial events already and more to come this year.
The fronts would be as simple as dismount your front struts, have a shop swap your strut components to new shock/spring and then re-install struts. Rears are extremely simple, swap spring and shock.
What do I dislike? Nothing. The setup could get a touch more agressive since I'm leaning toward all out competition performance, but for overall handling, great. Much better than the days of old rolling around with those shit HAL shocks and soft springs. Felt like I was driving a boat just to get a decent 60'. No thanks.
Accompany your new suspension with decent rubber, no "suma-tuma tires"!
