CLC85TA
Guy I work with just picked up a 96 Grand Marquis and it's not running right once the car gets up to temp. It looses power i.e. won't accelerate normally, bogs out. Runs fine when cold, has good power.
The plugs were just replaced, all the connections were dried out after the car was washed inside and out. A code came up as a #7 misfire when he had it scanned.
Sounds like he has a vacuum leak as well, I haven't heard it yet, which I'll do on my lunch break.
any ideas? I've known the IAC to be a problem. I'm gonna go check the plug wires over, he said they have some wear, but don't look original.
Thanks for your help,
Ryan
Ryan
