Heads, carbs, intakes, cams
y2kr
Heads, Edelbrock Victor Jr, Ford GT40 Iron
Edelbrock Victor Jr - 2.055 intake, 1.625 exhaust valves, bowls cleaned up, exhaust ports polished, intake matched to 1262. Hydraulic roller springs good to .600" lift. New valve seals, guide plates and 7/16 studs. Fresh setri valve job and deck surfaced. Clean ready to bolt on. $950.
GT40 Iron - 93 Cobra, 3 bar, casting number F3ZE. 1.840 intake, 1.540 exhaust valves, bowls cleaned up, exhaust matched to 1415, intake matched to 1250. Comes with Crane Cobra 1.73 to 1 roller rockers. Clean and ready to bolt on. $500.
EFI Intakes and Throttle Bodies
Small Block Ford EFI Intakes
351W GT40 – Polished Tubular Upper, Gray Lower, $550
351W GT40 – Painted Explorer Upper, Gray Lower, $450
302 94/95 Cobra – Polished Upper, Cobra Lower, $400
Small Block Ford EFI Throttle Bodies
BBK 80mm – Used, Fox Body, With TPS Sensor, $160
BBK 75mm – Used, Fox Body, With TPS Sensor, IAC, EGR Spacer, $170
Professional Products 75mm – Used, 94/94, Polished, With TPS Sensor, IAC $80
Small Block Chevy EFI
Holley Stealth Ram – New, Plenum cut 1” to fit under stocker hood of C4 Corvette, $600
Arizona Speed TPI – Big Tube Runners, Polished, Tapped For Nitrous, Fully Ported Stock Lower, Ported Plenum, $600.
Small Block Chevy EFI Throttle Bodies
BBK 58mm TPI Twin – Used, With TPS Sensor, $160
Arizona Speed 52mm TPI - Used, With TPS Sensor, $130
Small Block Ford Camshafts
TrickFlow – Used, Stage 3, $130
FMS - Used X303, Used, $110
FMS – Used Z303, Used, $130
Unknown Brand - .Used 536” Intake, .510” Exhaust, $100
Comp - Used, Retrofit, 35-000-8, 3150/3151HR10, Both I & E lift .512", I 303, E 319 duration, RPM range 3500-6800, $150
Comp - Used, Retrofit, 35-000-8, 3288/3289 HR12, Both I & E lift .585", I 265, E 274 duration, RPM range 1200-5300, $150
Carbs
Speed Demon 850 – Used, Vac Sec, $300
Speed Demon 850 – Rebuilt, Mech Sec, $350
[email protected]
517-750-9363
Ken
