Having trouble with my fan
Det_Riot
Just did a h/c/i on my 94 gt , everything was working good then when i went to get my tune, my electric fan just stopped working. Had it set to turn on at 190* and i cant figure out what is wrong with it.
I know the fan motor is still good, I jumped the fan motor off a different ground and hot wire and it worked fine..
I tried turning the ac on to see if the fan would turn on and got nothing. Unplugged the wires to check if it's even getting power and didnt get anything on my test probe on the high or low wires.
I'm thinking it could be the ccrm relay but i'm not sure how to test is that is the problem or not. Can I unplug the connector from the ccrm, and test light the pins to see if I have power coming into it?
