moneypit
below are the specs from greenlee
this saw is used but in great condition, the leg uprights to cross brace have been rewelded due to a factory cold weld works perfect , Ill have pictures tomorrow as its in my truck and I cannot remove it by myself, saw also comes with 2 new spare blades 100% USA MADE even the electric motor, has a built in wheel system to roll it around a shop, asking 675.00 can deliver for the cost of Gas (im willing to drive 5 hours each way) Im located in brighton Michigan Just outside Ann Arbor Ill have actuall Pics of the unit tomorrow provided my buddy arrives to help me unload saw sells for over 4k new
5 hours is most of Ohio, indiana and chicago
Spec:
Capacity: Rectangular 9-1/2" x 11" (241.3 x 279.4 mm); Round 9-1/2" Dia. or 8" Pipe (241.3 mm); 45° Angle 5-1/2" x 5-1/2" (139.7 x 139.7 mm); Vertical Work Table 7-5/8" x 10" (193.7 x 254.0 mm); Throat Height 9-1/2" (241.3 mm); Throat Depth 6-1/4" (158.8 mm) Dimensions: 52" h. x 47" l. x 27" w. (13208 h. x 11938 l. x 685.8 w. mm) Power Source:120 VAC 1/2 Horsepower. Weight: 346 lbs. (157 kg) Blade Size: 1/2" x .025" x 93" (12.7 mm x 0.64 mm x 2362 mm)
Description:
Cuts up to 8" pipe and 9-1/2" x 11" (241 x 280 mm) tray or duct.
Convertible to wet cutting systems with optional accessories.
Three sawing speeds 76, 141, and 268 feet per minute (23, 43, and 82 meters per minute).
Converts to vertical in seconds.
Automatic shut-off after cut is complete.
Sturdy wheels for mobility and stability.
Heavy-duty, adjustable hydraulic feed.
Heavy-duty, steel bed with welded steel legs.
Spec:
Description:
