red347lx
Today I picked my truck up from a body shop who had done some work for me on my truck. I drove it about 6-8 miles and my dash starting sounding off that the "oil pressure was low" and to stop the vehicle. I did and pulled over and noticed nothing wrong with the engine as far as ticks or noise that would accompany the low oil pressure.
The truck is an 09 Sierra with the 5.3l
I called the dealer and was told that it could be a bad oil pressure sending unit or Oil pressure sensor or something along those lines. He said 9 out of 10 times a filter is clogged causing the code to alarm that pressure is low. I got online and goggled the symptoms and read that by changing the oil pressure sensor on top of the motor and removing the screen would fix this issue.
The truck has 62k on it and never had any issues before this. Does this sound like the cause of a faulty sensor or sending unit? Am I looking for a sending unit or sensor or are they the same?
Any help would be greatly appreciated.
