2L8IWIN
Hey Guys,
I have a 6.2L L92 in an Escalade that is making a noise that I need help diagnosing.
It only does it after 2nd gear (part throttle) and gets louder as you climb through the gears (loudest 1200-2000rpms). Its most noticeable in 4th, 5th & 6th when cruising around and slowly accelerating/maintaining speed.
No sounds at start up, idle, free rev, or throughout first gear 900-6000RPM that i can hear. If I do a manaul gear select and keep it in first and mash the gas/brake to load the engine/let the RPMS climb I dont hear anything.
I dont think its anything internal like a bearing, wrist pin, lifter, etc as it would scream out at me in 1st under load.
Here is a video of it. This is from a stop up to 4th at about 40. You can really hear it around the 49-55 second mark.
Could it be detonating/pre-ignition from bad knock sensors? I was going to burn up the rest of this 87 and run some 92 and see if it helped.
Transmission/converter?
http://www.youtube.com/watch?v=BRylLOa0agA
