Gear experts
SSunset
Tell me what you see.
Looks like a used ring & pinion? (Note: you cannot change the pattern on a used gear)
Drive is normal, coast is off.
If preloads are correct and lash is .008"-.010 run it.
It howls badly light throttle.
I am assuming at this point the gears aren't causing the noise and its probably a pinion bearing.
Would you agree?
Backlash is .008
Thanks for the feedback
Would you agree?
Backlash is .008
No. Bad Bearings do not howl. Nor are they throttle sensitive (unless preload is gone and the pinion or carrier are floating).
Sounds like your describing a worn ring & pinion that noisy on the float.
Cant tell from the gear surface. If it has scores/burn marks or is excessively shiny it would be bad/make noise.
Did you keep the pinion shim with the housing?
That looks like a spool. I take it this is for drag racing. Solid bushings or anything that would transfer the noise like solid ladder bars?
Wavetrac
4.11
Honestly 99% street driving.
Video of the ring gear
http://youtu.be/l7wpWRkgSfY
I have 10k miles on this rearend since new and 10 passes at the track if that. Bolt ons only, no High HP car here.
Ok, made a little progress.
there were 3 shims on the pinion
going from the back of the car forward
.5mm or .020 inch
.25mm or .010 inch
.4mm or .015inch
1.15mm or .045 inch
