garbage clean out, sbf, ls parts, tires..odds n ends
dudek
more stuff will be added over the next few days
edit more added prices dropped, stuff needs to go!
pictures of everything can be seen in this link
http://s47.photobucket.com/albums/f184/Dudek21590/
everything is obo and open to trades
sbf trick flow valve covers, fresh matte black powdercoat couple days ago - 100 obo
302 arp head studs - everything is here 65 bucks
mustang 302 motor mounts includes k member nuts - 5 bucks
gt40 intake gaskets
65mm throttle body gaskets 20 bucks takes all
random 302 gaskets
302 e7 heads - 40 bucks
t5 spec 1 mustang clutch kit, in good shape with lots of life left - 125 bucks http://www.americanmuscle.com/spec-stage1-t45-transmission.html
4 goodyear fortera tires 245/65/17, they have prolly about 30% life left, check pics for yourself - 60 bucks obo
4 s10 rims, 3/4 tires hold air but all need to be replace. 205/75/15 is current tire size - 50 bucks obo
2007 6.0 ly6 truck motor pull offs, motor had 96k on it
l92 style truck intake with fuel rail, injectors and throttle body - 200
motor mounts - 20 bucks
ac compressor bracket - 10 bucks
vvt cam and cam gear - 100 bucks
8.1l vortec big block, has cam lifters and crankshaft - 400
14bolt chevy rear axle...dont know many details on it other then its complete - 150
FOr the sumped tank, do you have the plastic cover? Can you send me pics of the tank. 734 341 2210 Thanks
yessir, a certain member has been giving me the run around on it for 2 weeks now so its yours if you want it
