Garage Flooring Project
GreyGhost
I'm tired of looking at the stained concrete in my "work" garage, so once the weather improves, I'm going to clear it out and do something with it, so I need suggestions.
I know painted floors can be durable if done correctly and the plastic snap together floor tiles are a good alternative, but has anyone tried using ceramic tiles? I've seen them used in southern garages, but with the temperature range in Michigan, are they a viable option? I use jacks and stands in this garage, so there is also concern about cracking tiles? Has anyone else tried these? Any thoughts or suggestions?
By the way, indoor/outdoor carpeting is not an options since my junk leaks toooo much.
